QN9080 SC TIMERS
QN9080 SC TIMERS
1,025件の閲覧回数
suraj
Hi team,
Presently am working on SC Timers in QN9080 Eval board, am trying to calculate match value to set timer interrupt for 1us and am using 'ctimer_simple_match' driver example, below is the timer configuration
1) When am configuring matchConfig.matchValue to 16000000 am getting 1sec = on time and 1sec = off time, verified by toggling GPIO and generating interrupt for every 1sec
2) How should I calculate to generate interrupt for 1us, 1ms, could you derive formulae for configuring value for matchConfig.matchValue ?
3) Whats the need of prescalar ? In my case prescalar was configured as zero ..
matchConfig.enableCounterReset = true;
matchConfig.enableCounterStop = false;
matchConfig.matchValue = 16000000;//BUS_CLK_FREQ / 4; //1Sec interrupt
matchConfig.outControl = kCTIMER_Output_Toggle;
matchConfig.outPinInitState = true;
matchConfig.enableInterrupt = false;
Please solve my issue ASAP
Thanking you
Suraj, N
0 返答(返信)
