QN9080 Keil Pack
QN9080 Keil Pack
3,273件の閲覧回数
tmihajloski
The QN9080 packs for uVision Keil do not have the processor specific interrupts labeled. I am using pack version 1.1.5
Below is the list I get for the QN9080
Below is an example from a from a CM4 part by STMicro.
タグ(2)
5 返答(返信)
3,101件の閲覧回数
stephanie_m
By any chance, have you checked this Keil post?
µVISION DEBUGGER: missing interrupt names at NVIC window
I believe that it what it's happening to you, could you please confirm if the problem gets solved when following their indications?
 Estephania
3,101件の閲覧回数
tmihajloski
The post is about uVision 5.18 or older I am using 5.26. Also in my original post I have screencaps from my environment one from a the NXP pack and the other from an STM pack. The STM pack has labels for all additional IRQs.
3,101件の閲覧回数
stephanie_m
Are you sure your device has the complete IC pack installed? Could you please verify it ?
Does that message appear to you?
3,101件の閲覧回数
tmihajloski
Yes, the pack is installed, I can view the rest of the peripherals with full description of the registers. It is only the interrupts that are not labeled.
Can you reproduce the screen shots that I posted?
Sent from my Sprint Samsung Galaxy S9.
3,101件の閲覧回数
stephanie_m
After some investigation, the issue was reproduced and reported.; nonetheless, we do not have an estimated date for it to be corrected in the IDE.
Meanwhile, you can see the names of those vectors by looking at Table 49 of the QN9080 User Guide
Sorry for the inconvenience this might cause you.
