QN902X hids example
QN902X hids example
3,839件の閲覧回数
sergioa
Hello i like to know how can i test hids example for qn9020.
Because the nxp qtool doesn't have HOGPD (HID Profile Device Role) client to test.
thanks in advance.
4 返答(返信)
3,563件の閲覧回数
sergioa
Hello chi zou I see it with JTAG the example work fine.
Try to see the buffer of HID.
Regards.
3,563件の閲覧回数
gerardo_rodriguez
Hello Sergio,
You can use the "prj_client" demo appplication to test most of the BLE peripherals. In your case you need to enable the HID Host macros in "\prj_client\src\usr_config.h":
///HID Profile Report Host Role
 #define CFG_PRF_HOGPRH
 #define CFG_TASK_HOGPRH TASK_PRF1‍‍‍‍‍‍
Open a serial terminal @ 115200 bauds an go to through the menu to connect to the HID device and Enable the report Mode in the HOGH menu. Make sure that your terminal transmits New-lines as CR-LF ('\r''\n').
The HID device can also be connected to any Bluetooth Smart Ready products available on the market that supports HID devices.
Regards.
3,563件の閲覧回数
chizou
hello Gerardo Rodríguez ,
now i want  use example of hids to make a Bluetooth Keyboard,but the example is a mouse .Can you provide an example of a keyboard。
I've been doing it for two weeks,  but I can't do it.  Now I need your help very much。
3,563件の閲覧回数
chizou
I have test this example,but ,I dont see the  report data of sending by hid_device. how can i see that?
