QN9020 B3 HardFault_Handler  Problem
2,317 次查看
dengqiang
1.When qppc connected with qpps ,when connected,the uart0 receive MCU's data.
2.then disconnected qpps(shutdown qpps's power),but qppc recongnise the qpps down after 3 seconds .in the 3 seconds,the data always receive.
3.repeate the connect and disconnect,the QN9020 B3 will enter the HardFault_Handler .
标记 (1)
2,165 次查看
dengqiang
shut down ,cut the power,poweroff the qpps.The Question of the code's version is 1.3.6.
2,165 次查看
mario_castaneda
Hi Deng,
Did you download the last SDK (REV 1.3.9)?
a highly extensible platform for application development of QN9020|NXP
Mario
2,165 次查看
mario_castaneda
Hi Deng,
Then disconnected qpps(shutdown qpps's power), but qppc recognise the qpps down after 3 seconds.
Could you please explain how are you shut down the qpps's power?
Mario
