Please help me understand BeeStack Node_Desc_req pSequenceNumber
atillametetured
Contributor V
Below is the ASL_Node_Desc_req function from bee stack. (ASL_Zdpinterface.c)
void ASL_Node_Desc_req
zbCounter_t *pSequenceNumber,
zbNwkAddr_t aDestAddress
I cannot understand what the sequence number is, how it should be set and what it does. Can someone please enlighten me on this?
Mete
Labels (2)
jorge_a_vazquez
Hi Atilla
Please refer to "8.6 Device and service discovery – client services" chapter from the Software Reference Manual for ZigBee document, you should be able to locate it in the path <Kinetis_BeeStack_5.0.0_path>\doc. it is named as BSSRMZB2007.pdf
Hope this information helps you
Jorge Alcala
