NFC evaluation board
1,745件の閲覧回数
Shashank2
Hi team, i want to develop NFC based application so may i get list of evaluation boards/Development boards ?
And i also went through some of part number and i found out that PN7362 would suit to my application, so may i know which evaluation board has PN7362 ?
1,724件の閲覧回数
Fabian_R
Hello, sir.
Is great to know that you are interested in our products.
PN7462 Evaluation Board is used to create solutions based on the PN7362 IC. As you are able to check in the Datasheet, PN7362 is a programmable Cortex-M0 MCU that works with contactless cards.
We recommend using our NFC Reader Library, which will help you accelerate your development.
Fabian
