NCJ29D6 FlexCAN Initialization
Jinyu_Ren
Hello, everyone.
    I was using the development board of NCJ29D6, trying to run the official CAN routine, but the initialization process directly resulted in hardware errors. Other than turning off the watchdog, no other changes have been made. Is there anything else I should be aware of?
NguyenDat
Hello  Ren,
I'm not from NXP. I hope your problem will be fix soon.
Do you mind if I ask How can you buy the development board of NCJ29D6 ?
