MRF21030LDMOS 's ADS2011 Model
2,391 次查看
开龙王
Hi,I want the MRF21030LDMOS 's ADS2011 Model ,but I can not find it ,could you help me ?
2,252 次查看
Wlodek_D_
Senior Contributor II
The MRF21030 LDMOS family transistor is an old product, currently it is no longer manufactured.
In this case there are only older model versions available.
The latest MRF21030 ADS model you can find in Archived MET and Root LDMOS Models for Agilent's ADS v2001.1001
( http://www.freescale.com/webapp/sps/site/overview.jsp?code=RF_LDMOS_ARCHIVED_AGLNTADS_V1001&fsrch=1... ).
Please note that archived models from mentioned page are provided "as-is".
For more info about models and its use please see info on page mentioned above.
I believe this info will help you. If yes, then please mark this as Correct Answer.
Wlodek_D.
