MKW36 VDD_1P8Out issue
Sharma
Hello NXP Team,
 We are using MKW36A512VFT4  as wireless BLE controller in my application. The application periodically acquires Tri-axis accelerometer data using SPI com in MKW36 and transfers periodic data to mobile App via BLE communication.
We are using MKW36 in Buck Mode power supply with the following connections:
Pins PSWITCH, DC_DC CFG, VDD_0, VDDA,VDD_1, VDCDC_IN, VREFH are connected to 3.3V with multiple 10uF/0.1uF Decoupling capacitors.
Pins  VDD1P5OUT, VDD_RF1,VDD_RF2,VDD_RF3 are connected together and  decoupling capacitor 10uF/0.1uF added to GND
Pins DC_DC_LP, DC_DC_Ln_1 are connected using a 10uH inductor
Pins VREFL, VSSA , GANT are connected GND
     With the above power supply configuration, MKW36 can be programmed if the unused pin VDD_1POUT is left unconnected. If a Filter capacitor 10uF is used for the internal LDO, we are not able to program the MKW36 using MCU express . So can we keep the unused VDD_1POUT pin leave open in the ckt.?
Is MKW36 works only with inverted F antenna  and doesn't work with PCB antenna like ANT3216A063R2400A ?. Please clarify
Sharma
Ricardo_Zamora
Hope you are doing well. Can you please clarify what pin are you referring to? VDD_1P8OUT?
What DCDC mode are you using? You can refer to: AN5025.pdf
And related the antenna, you can refer to: Hardware Design Considerations for MKW35A/36A/35Z/36Z Bluetooth Low Energy Devices (section 5.3).
For example, our FRDM can be used with the printed f antenna, or switch to an external antenna connected to the SMA RF port.
Ricardo
Sharma
Hello Ricardo,
 I am doing good. Thanks for your quick reply on my query.
Here are the  additional details on my question especially VDD_1P8 supply line.
We referred to the document  AN5025 while designing  power supply section for the application. We used Buck Mode of operation with AutoStart option as below with slight modification.
In my last query, I was referring to the pin VDD_1P8. We had connected VDD_0 and VDD_1 to 3.3V source since we have an external accelerometer (3.3v ) connected on  SPI communication  to MKw36. Similarly we had connected VREFH,VDDA to 3.3V to power  Analog section. Also we understood that it is recommended to connect a 10uF capacitor to GND  for the VDD_1P8 pin.
     With the above connection, If the VDD_1P8 pin is terminated using a 10uF capacitor to GND, we were not able to program the MKW36. If we keep the VDD_1P8 pin left open( No capacitor to GND),  able to program the MKW36 IC using MCU Expresso. So in our design, do we need to keep the LDO o/p pin left open.
Let me know if you need any additional info on this query.
Sharma
Ricardo_Zamora
I would recommend following the recommended design from the Application Note.
Using another configuration of DCDC, could cause unexpected behavior.
Ricardo
Sharma
Hello Recardo,
 In our design, especially  VDD_0  and VDD_1 are connected to 3.3V since we have an I/O interface (Tri axis accelerometer ) device  operating at 3.3V connected over SPI to MKW36 IC. Similarly to get better ADC resolution and noise immunity, we have connected  VDDA and  VREFH to 3.3 V. More over as per AN5025 application note, they are all 3.3V compatible , ( VDD_0  , VDD_1 , VDDA and  VREFH )  .
   So I am not sure the issue with our current design in keeping VDD_1P8 Out pin connected across capacitor to GND . Can I continue to use the same design by keeping VDD_1P8 Out pin open?
Sharma
Sharma
Hello Ricardo,
 Referring to Application note, can I use a single 3V coin cell battery  to power up the MKW36 IC in bypass Mode as below. Please let me know.
Ricardo_Zamora
I would recommend checking this community post:
KW35_36 Bluetooth LE Power Profile Calculator Tool
Ricardo
%3CLINGO-SUB%20id%3D%22lingo-sub-2298215%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMKW36%20VDD_1P8Out%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298215%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20NXP%20Team%2C%3C%2FP%3E%3CP%3E%26nbsp%3BWe%20are%20using%20MKW36A512VFT4%26nbsp%3B%20as%20wireless%20BLE%20controller%20in%20my%20application.%20The%20application%20periodically%20acquires%20Tri-axis%20accelerometer%20data%20using%20SPI%20com%20in%20MKW36%20and%20transfers%20periodic%20data%20to%20mobile%20App%20via%20BLE%20communication.%3C%2FP%3E%3CP%3EWe%20are%20using%20MKW36%20in%20Buck%20Mode%20power%20supply%20with%20the%20following%20connections%3A%3C%2FP%3E%3CP%3EPins%20PSWITCH%2C%20DC_DC%20CFG%2C%20VDD_0%2C%20VDDA%2CVDD_1%2C%20VDCDC_IN%2C%20VREFH%20are%20connected%20to%203.3V%20with%20multiple%2010uF%2F0.1uF%20Decoupling%20capacitors.%3C%2FP%3E%3CP%3EPins%26nbsp%3B%20VDD1P5OUT%2C%20VDD_RF1%2CVDD_RF2%2CVDD_RF3%20are%20connected%20together%20and%26nbsp%3B%20decoupling%20capacitor%2010uF%2F0.1uF%20added%20to%20GND%3C%2FP%3E%3CP%3EPins%20DC_DC_LP%2C%20DC_DC_Ln_1%20are%20connected%20using%20a%2010uH%20inductor%3C%2FP%3E%3CP%3EPins%20VREFL%2C%20VSSA%20%2C%20GANT%20are%20connected%20GND%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BWith%20the%20above%20power%20supply%20configuration%2C%20MKW36%20can%20be%20programmed%20if%20the%20unused%20pin%20VDD_1POUT%20is%20left%20unconnected.%20If%20a%20Filter%20capacitor%2010uF%20is%20used%20for%20the%20internal%20LDO%2C%20we%20are%20not%20able%20to%20program%20the%20MKW36%20using%20MCU%20express%20.%20So%20can%20we%20keep%20the%20unused%20VDD_1POUT%20pin%20leave%20open%20in%20the%20ckt.%3F%3C%2FP%3E%3CP%3EIs%20MKW36%20works%20only%20with%20inverted%20F%20antenna%26nbsp%3B%20and%20doesn't%20work%20with%20PCB%20antenna%20like%26nbsp%3B%3CSPAN%3EANT3216A063R2400A%20%3F.%20Please%20clarify%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ERegards%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESharma%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MKW36%20VDD_1P8Out%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Ricardo%2C%3C%2FP%3E%3CP%3E%26nbsp%3BI%20am%20doing%20good.%20Thanks%20for%20your%20quick%20reply%20on%20my%20query.%3C%2FP%3E%3CP%3EHere%20are%20the%26nbsp%3B%20additional%20details%20on%20my%20question%20especially%20VDD_1P8%20supply%20line.%3C%2FP%3E%3CP%3EWe%20referred%20to%20the%20document%26nbsp%3B%20AN5025%20while%20designing%26nbsp%3B%20power%20supply%20section%20for%20the%20application.%20We%20used%20Buck%20Mode%20of%20operation%20with%20AutoStart%20option%20as%20below%20with%20slight%20modification.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sharma_0-1769146921284.png%22%20style%3D%22width%3A%20734px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sharma_0-1769146921284.png%22%20style%3D%22width%3A%20734px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sharma_0-1769146921284.png%22%20style%3D%22width%3A%20734px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sharma_0-1769146921284.png%22%20style%3D%22width%3A%20734px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sharma_0-1769146921284.png%22%20style%3D%22width%3A%20734px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sharma_0-1769146921284.png%22%20style%3D%22width%3A%20734px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374000iCC7D0FEEB1BBF992%2Fimage-dimensions%2F734x275%3Fv%3Dv2%22%20width%3D%22734%22%20height%3D%22275%22%20role%3D%22button%22%20title%3D%22Sharma_0-1769146921284.png%22%20alt%3D%22Sharma_0-1769146921284.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EIn%20my%20last%20query%2C%20I%20was%20referring%20to%20the%20pin%20VDD_1P8.%20We%20had%20connected%20VDD_0%20and%20VDD_1%20to%203.3V%20source%20since%20we%20have%20an%20external%20accelerometer%20(3.3v%20)%20connected%20on%26nbsp%3B%20SPI%20communication%26nbsp%3B%20to%20MKw36.%20Similarly%20we%20had%20connected%20VREFH%2CVDDA%20to%203.3V%20to%20power%26nbsp%3B%20Analog%20section.%20Also%20we%20understood%20that%20it%20is%20recommended%20to%20connect%20a%2010uF%20capacitor%20to%20GND%26nbsp%3B%20for%20the%20VDD_1P8%20pin.%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BWith%20the%20above%20connection%2C%20If%20the%20VDD_1P8%20pin%20is%20terminated%20using%20a%2010uF%20capacitor%20to%20GND%2C%20we%20were%20not%20able%20to%20program%20the%20MKW36.%20If%20we%20keep%20the%20VDD_1P8%20pin%20left%20open(%20No%20capacitor%20to%20GND)%2C%26nbsp%3B%20able%20to%20program%20the%20MKW36%20IC%20using%20MCU%20Expresso.%20So%20in%20our%20design%2C%20do%20we%20need%20to%20keep%20the%20LDO%20o%2Fp%20pin%20left%20open.%3C%2FP%3E%3CP%3ELet%20me%20know%20if%20you%20need%20any%20additional%20info%20on%20this%20query.%3C%2FP%3E%3CP%3ERegards%3C%2FP%3E%3CP%3ESharma%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2298546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MKW36%20VDD_1P8Out%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2298546%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHope%20you%20are%20doing%20well.%20Can%20you%20please%20clarify%20what%20pin%20are%20you%20referring%20to%3F%20VDD_1P8OUT%3F%3C%2FP%3E%0A%3CP%3EWhat%20DCDC%20mode%20are%20you%20using%3F%20You%20can%20refer%20to%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN5025.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN5025.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EAnd%20related%20the%20antenna%2C%20you%20can%20refer%20to%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12181.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EHardware%20Design%20Considerations%20for%20MKW35A%2F36A%2F35Z%2F36Z%20Bluetooth%20Low%20Energy%20Devices%3C%2FA%3E%20(section%205.3).%3C%2FP%3E%0A%3CP%3EFor%20example%2C%20our%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2Fgeneral-purpose-mcus%2Ffrdm-development-kit-for-kinetis-kw36-35-34-mcus%3AFRDM-KW36%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EFRDM%3C%2FA%3E%20can%20be%20used%20with%20the%20printed%20f%20antenna%2C%20or%20switch%20to%20an%20external%20antenna%20connected%20to%20the%20SMA%20RF%20port.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards%2C%3C%2FP%3E%0A%3CP%3ERicardo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2301466%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MKW36%20VDD_1P8Out%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2301466%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20would%20recommend%20following%20the%20recommended%20design%20from%20the%20Application%20Note.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EUsing%20another%20configuration%20of%20DCDC%2C%20could%20cause%20unexpected%20behavior.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards%2C%3C%2FP%3E%0A%3CP%3ERicardo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2302104%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MKW36%20VDD_1P8Out%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2302104%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Ricardo%2C%3C%2FP%3E%3CP%3E%26nbsp%3BReferring%20to%20Application%20note%2C%20can%20I%20use%20a%20single%203V%20coin%20cell%20battery%26nbsp%3B%20to%20power%20up%20the%20MKW36%20IC%20in%20bypass%20Mode%20as%20below.%20Please%20let%20me%20know.%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sharma_0-1769594863462.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sharma_0-1769594863462.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sharma_0-1769594863462.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sharma_0-1769594863462.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F374592i56EB14B999E36BF5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sharma_0-1769594863462.png%22%20alt%3D%22Sharma_0-1769594863462.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2301863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MKW36%20VDD_1P8Out%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2301863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Recardo%2C%3C%2FP%3E%3CP%3E%26nbsp%3BIn%20our%20design%2C%20especially%26nbsp%3B%20VDD_0%26nbsp%3B%20and%20VDD_1%20are%20connected%20to%203.3V%20since%20we%20have%20an%20I%2FO%20interface%20(Tri%20axis%20accelerometer%20)%20device%26nbsp%3B%20operating%20at%203.3V%20connected%20over%20SPI%20to%20MKW36%20IC.%20Similarly%20to%20get%20better%20ADC%20resolution%20and%20noise%20immunity%2C%20we%20have%20connected%26nbsp%3B%26nbsp%3BVDDA%20and%26nbsp%3B%26nbsp%3BVREFH%20to%203.3%20V.%20More%20over%20as%20per%20AN5025%20application%20note%2C%20they%20are%20all%203.3V%20compatible%20%2C%20(%20VDD_0%26nbsp%3B%20%2C%20VDD_1%20%2C%20VDDA%20and%26nbsp%3B%26nbsp%3BVREFH%20)%26nbsp%3B%20.%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3BSo%20I%20am%20not%20sure%20the%20issue%20with%20our%20current%20design%20in%20keeping%20VDD_1P8%20Out%20pin%20connected%20across%20capacitor%20to%20GND%20.%20Can%20I%20continue%20to%20use%20the%20same%20design%20by%20keeping%26nbsp%3BVDD_1P8%20Out%20pin%20open%3F%26nbsp%3B%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3ESharma%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2305554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MKW36%20VDD_1P8Out%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2305554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI%20would%20recommend%20checking%20this%20community%20post%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FWireless-Connectivity-Knowledge%2FKW35-36-Bluetooth-LE-Power-Profile-Calculator-Tool%2Fta-p%2F1111885%22%20target%3D%22_blank%22%3EKW35_36%20Bluetooth%20LE%20Power%20Profile%20Calculator%20Tool%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards%2C%3C%2FP%3E%0A%3CP%3ERicardo%3C%2FP%3E%3C%2FLINGO-BODY%3E
