MKW21 Transmit Current
jssn
What is the MKW21 transmitter current consumption when the output power is set to 8dBm?
Labels (2)
antonioconcio
We are in the process to update the MKW2xD Datasheet. Please see below the graph of what you are looking for:
I hope it helps,
Antonio
jssn
The datasheet specifies the current at 0dBm output power only. Has anyone measure the current at higher transmit powers?
