MKW21 Transmit Current
2,964件の閲覧回数
jssn
What is the MKW21 transmitter current consumption when the output power is set to 8dBm?
ラベル(2)
2 返答(返信)
2,253件の閲覧回数
antonioconcio
We are in the process to update the MKW2xD Datasheet. Please see below the graph of what you are looking for:
I hope it helps,
Antonio
2,253件の閲覧回数
jssn
The datasheet specifies the current at 0dBm output power only. Has anyone measure the current at higher transmit powers?
