Kinetis Connectivity Software Version 1.0.2
2,781件の閲覧回数
petertoenz
Hello
I saw today that a new version 1.0.2 of the kinetis connectivity software is available and it is listet unter the KW40 processor. After the download and install of this framework I saw scared that it supports only the kw41 processor!!!
Will the kw40 processor be supportet in the future or can I use our board with the KW40 as a paperweight (The version #1.0.1 is realy unstable in the scope of establish a connection!)
Peter
PS: Sorry for my bad english!
ラベル(2)
2 返答(返信)
2,379件の閲覧回数
alex_yang
I just saw those two software, and I was so disappointed. The demo is so complicated.
 they just playing their C techniques and build demo for their own, not the customers!. While the SDK2.0 it self’s driver example is better.
We only need the SIMPLEST driver API code to send and receive radio data, not their endless status machine, lots of global variables and OSA!.
2,379件の閲覧回数
jasonchiang
    If you only need the SIMPLEST driver API code to send and receive radio data, SMAC protocol maybe can fit your requirement. Below is the SMAC path under Connectivity SW 1.0.2 folder. You can refer this SMAC. Hoping this helps.pastedImage_1.png
