Hi, @Lu888
Thanks for creating case to us.
From your provided info, I think you can execute fuse-read command means you are not in "After OEM Open" state.
But according to:
KW47SRM.pdf
The reason is:
The RO in the following table indicates that user cannot use MGMT_FUSE_PROGRAM to write the lifecycle fuses, instead, he can use MGMT_ADVANCE_LIFECYCLE or MGMT_SET_RETURN_FA_MODE.
If you want to change lifecycle, you can use this command: MGMT_ADVANCE_LIFECYCLE in SB3 file.
Christine.
