KW47: Using GPIO Port D
alanlow
I realized that there is no definition of kCLOCK_GpioD and kCOCK_PortD in the fsl_clock.h.
Is there any sample code to initialize Port D for KW47?
Thanks.
sofiaurueta
Hope you are doing well.
There is an example in the SDK that uses PTD1. You could use that implementation as a reference for configuring the PORT D GPIO.
Although using Config Tools with wireless examples is not recommended as it may modify required configurations, you can create a blank project to generate the code that enables the port using Config Tools and then manually copy that code into your existing project.
Ana Sofia.
alanlow
Hi Sofia,
Thanks for your quick response. May I know which example you are reference?
Thanks!
sofiaurueta
The implementation is included in the SDK, please see in pin_mux.c file, the function BOARD_InitPinButton0 which configures the pin routing for PTD1, as well as defines for GPIOD, PORTD in pin_mux.h file.
Ana Sofia.
tejoka5968
Hello!
On KW47, there are no kCLOCK_GpioD or kCLOCK_PortD definitions in fsl_clock.h because Port D isn’t part of the KW47 clock tree. Only ports A, B, C, and E are supported. To initialize a port, enable its clock with CLOCK_EnableClock(kCLOCK_PortX), set the pin mux using PORT_SetPinMux(), and then configure the GPIO with GPIO_PinInit(). For reference, check the KW47 SDK GPIO demos (like LED toggle) which show the correct initialization flow.
%3CLINGO-SUB%20id%3D%22lingo-sub-2321059%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKW47%3A%20Using%20GPIO%20Port%20D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321059%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EI%20realized%20that%20there%20is%20no%20definition%20of%20kCLOCK_GpioD%20and%20kCOCK_PortD%20in%20the%20fsl_clock.h.%3C%2FP%3E%3CP%3EIs%20there%20any%20sample%20code%20to%20initialize%20Port%20D%20for%20KW47%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2322126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW47%3A%20Using%20GPIO%20Port%20D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2322126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EThe%20implementation%20is%20included%20in%20the%20SDK%2C%20please%20see%20in%20pin_mux.c%20file%2C%20the%20function%20BOARD_InitPinButton0%20which%20configures%20the%20pin%20routing%20for%20PTD1%2C%20as%20well%20as%20defines%20for%20GPIOD%2C%20PORTD%20in%20pin_mux.h%20file.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EAna%20Sofia.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2321574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW47%3A%20Using%20GPIO%20Port%20D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321574%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%20Sofia%2C%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%20for%20your%20quick%20response.%20May%20I%20know%20which%20example%20you%20are%20reference%3F%3CBR%20%2F%3E%3CBR%20%2F%3EThanks!%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2321537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW47%3A%20Using%20GPIO%20Port%20D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3CBR%20%2F%3EHope%20you%20are%20doing%20well.%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThere%20is%20an%20example%20in%20the%20SDK%20that%20uses%26nbsp%3BPTD1.%20You%20could%20use%20that%20implementation%20as%20a%20reference%20for%20configuring%20the%26nbsp%3BPORT%20D%20GPIO.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAlthough%20using%20Config%20Tools%20with%20wireless%20examples%20is%20not%20recommended%20as%20it%20may%20modify%20required%20configurations%2C%20you%20can%20create%20a%20blank%20project%20to%20generate%20the%20code%20that%20enables%20the%20port%20using%20Config%20Tools%20and%20then%20manually%20copy%20that%20code%20into%20your%20existing%20project.%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%26nbsp%3B%3CBR%20%2F%3EAna%20Sofia.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2321095%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW47%3A%20Using%20GPIO%20Port%20D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2321095%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello!%3C%2FP%3E%3CP%3EOn%20KW47%2C%20there%20are%20no%20kCLOCK_GpioD%20or%20kCLOCK_PortD%20definitions%20in%20fsl_clock.h%20because%20Port%20D%20isn%E2%80%99t%20part%20of%20the%20KW47%20clock%20tree.%20Only%20ports%20A%2C%20B%2C%20C%2C%20and%20E%20are%20supported.%20To%20initialize%20a%20port%2C%20enable%20its%20clock%20with%20CLOCK_EnableClock(kCLOCK_PortX)%2C%20set%20the%20pin%20mux%20using%20PORT_SetPinMux()%2C%20and%20then%20configure%20the%20GPIO%20with%20GPIO_PinInit().%20For%20reference%2C%20check%20the%20KW47%20SDK%20GPIO%20demos%20(like%20LED%20toggle)%20which%20show%20the%20correct%20initialization%20flow.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
