KW41Z Thread
KW41Z Thread
5,438 次查看
sensenthuran
Can the  Home Kit sensors connect to KW41Z based border router network? , if so, how we should configure the KW41Z router to commission?
example sensors
Eve Door & Window - Apple HomeKit
https://www.amazon.ca/Eve-Door-Window-Automatically-Notifications/dp/B08BDM47S2?ref_=ast_sto_dp&th=1...
Wemo Smart Plug with Thread
https://www.amazon.com/HomeKit-Enabled-Automation-Compatible-Controller/dp/B09T4S3QKC/ref=sr_1_3?cri...
标签 (2)
5,196 次查看
patrick_pan
Hi, Sen
Theoretically the KW41 Thread BR is not HomeKit device, so it will not accept Homekit Accessory to join its network since the commissioning and pairing stages of Homekit Accessory requires either HW or SW MFI certified messages like credential / provisioning data be exchanged between Homekit Controller and Accessory. The KW41 Thread BR most probably will not provide these mandatory Homekit required information so Homekit Accessory wouldn't join it successfully.
B.R
Patrick
5,187 次查看
sensenthuran
Thanks @patrick_pan
We already tested KW41Z Thread Border gateway with Eval board sensors.
Would your recommend any commercial Thread sensors that can connect to NXP KW41Z Thread Border Gateway?
5,280 次查看
stephanie_m
Please help us checking this page with the current support of HOMEKIT , there you can also find some details on how to seek for more details as well.
