KW39 SDK sample code could not import issue.
2,350件の閲覧回数
StephenYeh
Hi Sir,
Would you help us to check the KW39 SDK could not import issue?
BRs.
3 返答(返信)
2,329件の閲覧回数
Ricardo_Zamora
Hope you are doing well. Could you please give us more details about the issue you are presenting?
What IDE are you using? What IDE version are you using? What SDK version are you using?
Ricardo
2,273件の閲覧回数
Jerry_Chang
MCUXpresso IDE v11.6.0 [Build 8187] [2022-07-13]
SDK_2_6_15_MKW39A512xxx4
We can not see any Example Code.
https://drive.google.com/file/d/1H0vFSFb3cZfj_R3AtJqG2CH8ZBmZjH2s/view?usp=drive_link
Warning: SDK Import Wizard is not available for device SDKs. Please select an item with board.
2,210件の閲覧回数
Ricardo_Zamora
Thank you for the information.
If you want to import an example for KW38's family, you would need to import the SDK for FRDM-KW38, import the example and then modify it with the configuration of MKW39.
If you need some extra guidance, please let me know.
Ricardo
