KW38 pair problem
KW38 pair problem
JackYu2
I have a KW38 Demo board. And Download test application frdmkw38_adv_ext_peripheral_freertos from SDK.
Connect the KW38 board by nrf Connect APP. It can found the device KW38.
When I Pair with it. Try PIN 0000 or 1234, It all fail.
The correct PIN for pair is ???
beckermann
Hello JackYu2,
You can find the passkey of the examples in app_preinclude.h, the define gPasskeyValue_c:
I.e. the default passkey is 999999.
Greetings
Andreas
