KW36A Wireless Ranging Techniques
danieltseng
Contributor V
1。Does KW36A's wireless ranging techniques support  RSSI, Phase, TOF ?
2。If there is support, which example of SDK and document for my reference ?
  • KW
stephanie_m
Hello ,
Our current SDK contains APIs to capture IQ, nonetheless, you will need to develop your own examples with those API's.
The API's can be found at the following path.
              <installation path>\ middleware\wireless\framework_x.y.z\XCVR\MKW36Z
You can find the APIs to capture IQ in the dbg_ram_capture or the dma_capture files, nonetheless, that it's the only information we have available for this matter, there is no documentation on this yet but the code comments on the files.
Estephania
