KW36 Localization
KW36 Localization
1,791 次查看
danieltseng
Refer to this link
KW35A/36A AoA or phase-based ToF APIs
1. What Localization (RSSI/ TOF / AOA / AOD…) does kw36 currently support ?
2. If there is support, does kw36 provide examples code?
  • KW
1,641 次查看
stephanie_m
As mentioned in the thread you posted, we only have the IQ captures and that is all the documentation available on the matter, is it up to every customer to implement their localization algorithm .
Sorry for the inconveniences this might cause you.
Estephania
