KW2x Linker File: Default memory format
1,845件の閲覧回数
jc_pacheco
The default configuration can be modified, however you should take care on other limitations that could appear when incorporating other sections.
+------------------+ -   __region_ROM_end__, FSL_PROD_DATA_START_ADDRESS
| FSL Prod Data |
+------------------+ -   FSL_PROD_DATA_END_ADDRESS, NV_STORAGE_START_ADDRESS
| NVM Region     |
+------------------+ -   NV_STORAGE_END_ADDRESS, INT_STORAGE_START
|  Int. Storage     |
+------------------+ -  INT_STORAGE_END
|  ROM region    |
+------------------+ -   __region_ROM_start__
|    Bootloader    |
+------------------+ -  __region_BOOT_start__
Location:  <Project location>\PLM\Linker_Config\MKW24D512V.icf or MKW21D256V.icf
ラベル(2)
0 返答(返信)
