[KW21Z] For compatibility with other zigbee IC. (Not NXP device)
waynejeong
Hello
I am considering developing a co-ordinator using KW21Z based Zigbee 3.0 stack. But I have concerns to implement co-ordinator for compatibility.
According to ZigBee 3.0 Devices User Guide (ZB3DEVUG),  There seems to be no problem with the compatibility with previous version.
Are there any case that KW21Z used with other devices(Not NXP) and previous zigbee version?
Thank you.
Sebastian_Del_Rio
Hi Young, I hope you're doing well!
The KW21Z's ZigBee 3.0 Stack supports connection with devices from other manufacturers, as long as the other devices support the use of the ZigBee 3.0 Stack. Compatibility will depend on the functionality and implementation of the ZigBee stack on the other devices.
Since ZigBee 3.0 implements and collects the previously defined market-specific profiles, it should be backwards compatible with devices of this types, and be able to interoperate between devices.
Please let me know if you need some more specific information.
Sebastian
