KW21Z Concurrent Zigbee and Thread
unknowncoder
I am investigating using using KW21Z for one of our existing IoT products. I would like to know if the KW21Z support concurrent Zigbee and Thread operation.
That is both protocols can be used at the exact same time.
Tags (3)
stephanie_m
It is possible in theory, nonetheless, there is no example for it and you will need to develop it by yourself, also you will need to consider the memory limitation of the chip in relation to your application size as well considering the footprint the stacks.
Estephania
