KW01 driver problems on Win10 x64
lexa5005
Hello everybody.
Anybody know, how can I connect KW01-Board to my PC.
When I tried to setup drivers from original BSP, I got a problem with digital sign of these drivers.
I restarted my computer in a special mode, which skips the digital sign validation, installing attempt was failed with
BSOD.
Anybody has experienced this problem on Win 10 x64? How can I resolve it?
  • KW
Tags (2)
stephanie_m
But is the device detected by the computer ? Have you tried updating the drivers from the device manager of windows? Are you using the freedom board or the MBR version of the board? Which IDE are you using to program your device ?
Estephania
lexa5005
Yes, device is detected. I tried to update the drivers and IDE using this link:
Modular Reference Boards for Kinetis KW0x | NXP.
I'm using MRB (Modular Reference Board) version of the board.
stephanie_m
As the  KW01 is already marked as not recommended for new designs, the support of the device is limited.
Currently those drivers is all we have available,  you can try using a virtual machine or use an external USB2SER.
Sorry for the inconvenience this might cause you
Estephania
