K32W148-EVK OTA updates
karamanr
I am trying to add the ota client into my application. I started by following this guide: https://www.nxp.com/docs/en/application-note/AN13855.pdf . I can see the application in both the UART and OTAP sections of the IoT Toolbox, however, the updates do not seem to make any changes. I tried both using a normal Wireless UART application and the UART-OTAP app, by changing the local name when advertising to something else than the default in the app_config.c file. The upload seems to be successful in both cases, but when the board resets, the app is still the old one. I have tried using both the internal and external storage, with the same result. I suspect that something has to be added/changed in the linker scripts, however the pdf file does not mention what file/variable/boot flag has to be changed. Is there something that I've missed or is my approach wrong?
Itzel_UV
Hello Ridvan,
Could you try following the steps from this guide to create an image with OTAP tool (Chapter 5)
Creating Firmware Update Image for KW45B41Z/K32W148 using Over the Air Programming Tool (nxp.com)? Please send update of your results.
Itzel
chris123951
Hi @karamanr , I saw you post and we are also struggling with similar issue, by any chance did you fix this issue. If yes, could you please share some insights.
karamanr
Hi @chris123951 , sorry for the late reply, the way I got it to work was to follow the guide from this link: https://www.nxp.com/docs/en/application-note/AN13860.pdf
The key thing about this is the way you create the update image it seems, at first I thought that I can only create it using MCUXpresso, however I only got my update to work by creating it using the NXP Over the Air Programming tool. Since I was working on Ubuntu, I did not have access to the tool so I thought that only using the .srec file from MCUXpresso would work, however it was not the case. After following the guide, I was able to update my application with a newer version using the IoT Toolboox iOS Application.
Kind Regards,
Ridvan
Itzel_UV
Hello Ridvan,
Itzel
karamanr
Any update @Itzel_UV ?
Itzel_UV
Have you already tried running the example from https://www.nxp.com/docs/en/application-note-software/AN13855SW.zip?
Have you made any other modification from the guide https://www.nxp.com/docs/en/application-note/AN13855.pdf?
Itzel
karamanr
I was not able to run the example as it is created for the KW45B41ZEVK, while I am using the K32W148-EVK. Is there a similar example for the board I am using? I can try to add the missing stuff and run it on my board, because from a quick look, most differences are board/device specific files. I have noticed some things that I did not have in my project, like these two lines in the linker script:
" m_hadmbuff_start = __base_RAM_VECTOR_TABLE + 0x400;
m_hadmbuff_size = 0x2000;"
However, even after adding them in the symbols.ldt file, the result was the same.
The only change I have made that is different from the guide was to set the gAppUseBonding_d and gAppUsePairing_d to 0 as I was having some issues when reconnecting to the device but I do not think this has any effect on the updating part. By using the debugger I was able to see that the update seems to transfer correctly, however when the device resets I get a OTACFG_FW_UDPATE_FAILURE(0x4412d283) value for update_status which according to the data sheet: "Indicates failure to process sb3 file OR failure to erase/write update status to OTACFG page". Any clue as to why this would happen? I am sending a .srec file created from the binary utilities of MCUXpresso through the NXP IoT Toolbox application on an iOS device if that helps.
Kind Regards,
Ridvan
Itzel_UV
I will be helping you at this case.
Could you tell me the SDK version that you're using?
karamanr
Hi, I am using the SDK_2.12.7_K32W148-EVK
%3CLINGO-SUB%20id%3D%22lingo-sub-1879967%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EK32W148-EVK%20OTA%20updates%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1879967%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3EI%20am%20trying%20to%20add%20the%20ota%20client%20into%20my%20application.%20I%20started%20by%20following%20this%20guide%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13855.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13855.pdf%3C%2FA%3E%20.%20I%20can%20see%20the%20application%20in%20both%20the%20UART%20and%20OTAP%20sections%20of%20the%20IoT%20Toolbox%2C%20however%2C%20the%20updates%20do%20not%20seem%20to%20make%20any%20changes.%20I%20tried%20both%20using%20a%20normal%20Wireless%20UART%20application%20and%20the%20UART-OTAP%20app%2C%20by%20changing%20the%20local%20name%20when%20advertising%20to%20something%20else%20than%20the%20default%20in%20the%20app_config.c%20file.%20The%20upload%20seems%20to%20be%20successful%20in%20both%20cases%2C%20but%20when%20the%20board%20resets%2C%20the%20app%20is%20still%20the%20old%20one.%20I%20have%20tried%20using%20both%20the%20internal%20and%20external%20storage%2C%20with%20the%20same%20result.%20I%20suspect%20that%20something%20has%20to%20be%20added%2Fchanged%20in%20the%20linker%20scripts%2C%20however%20the%20pdf%20file%20does%20not%20mention%20what%20file%2Fvariable%2Fboot%20flag%20has%20to%20be%20changed.%20Is%20there%20something%20that%20I've%20missed%20or%20is%20my%20approach%20wrong%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1879967%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EProduct%3A%20K32W1%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EProtocol%3A%20BLE%20-%26gt%3B%20connectivity%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1911389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20K32W148-EVK%20OTA%20updates%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1911389%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F214496%22%20target%3D%22_blank%22%3E%40chris123951%3C%2FA%3E%20%2C%20sorry%20for%20the%20late%20reply%2C%20the%20way%20I%20got%20it%20to%20work%20was%20to%20follow%20the%20guide%20from%20this%20link%3A%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13860.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13860.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3EThe%20key%20thing%20about%20this%20is%20the%20way%20you%20create%20the%20update%20image%20it%20seems%2C%20at%20first%20I%20thought%20that%20I%20can%20only%20create%20it%20using%20MCUXpresso%2C%20however%20I%20only%20got%20my%20update%20to%20work%20by%20creating%20it%20using%20the%20NXP%20Over%20the%20Air%20Programming%20tool.%20Since%20I%20was%20working%20on%20Ubuntu%2C%20I%20did%20not%20have%20access%20to%20the%20tool%20so%20I%20thought%20that%20only%20using%20the%20.srec%20file%20from%20MCUXpresso%20would%20work%2C%20however%20it%20was%20not%20the%20case.%20After%20following%20the%20guide%2C%20I%20was%20able%20to%20update%20my%20application%20with%20a%20newer%20version%20using%20the%20IoT%20Toolboox%20iOS%20Application.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EKind%20Regards%2C%3CBR%20%2F%3ERidvan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1898469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20K32W148-EVK%20OTA%20updates%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1898469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F192126%22%20target%3D%22_blank%22%3E%40karamanr%3C%2FA%3E%26nbsp%3B%2C%20I%20saw%20you%20post%20and%20we%20are%20also%20struggling%20with%20similar%20issue%2C%20by%20any%20chance%20did%20you%20fix%20this%20issue.%20If%20yes%2C%20could%20you%20please%20share%20some%20insights.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1885368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20K32W148-EVK%20OTA%20updates%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1885368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Ridvan%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECould%20you%20try%20following%20the%20steps%20from%20this%20guide%20to%20create%20an%20image%20with%20OTAP%20tool%20(Chapter%205)%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13860.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ECreating%20Firmware%20Update%20Image%20for%20KW45B41Z%2FK32W148%20using%20Over%20the%20Air%20Programming%20Tool%20(nxp.com)%3C%2FA%3E%3F%20Please%20send%20update%20of%20your%20results.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EItzel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1884212%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20K32W148-EVK%20OTA%20updates%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1884212%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3E%3CBR%20%2F%3EI%20was%20not%20able%20to%20run%20the%20example%20as%20it%20is%20created%20for%20the%20KW45B41ZEVK%2C%20while%20I%20am%20using%20the%20K32W148-EVK.%20Is%20there%20a%20similar%20example%20for%20the%20board%20I%20am%20using%3F%20I%20can%20try%20to%20add%20the%20missing%20stuff%20and%20run%20it%20on%20my%20board%2C%20because%20from%20a%20quick%20look%2C%20most%20differences%20are%20board%2Fdevice%20specific%20files.%20I%20have%20noticed%20some%20things%20that%20I%20did%20not%20have%20in%20my%20project%2C%20like%20these%20two%20lines%20in%20the%20linker%20script%3A%3CBR%20%2F%3E%22%20m_hadmbuff_start%20%3D%20__base_RAM_VECTOR_TABLE%20%2B%200x400%3B%3CBR%20%2F%3Em_hadmbuff_size%20%3D%200x2000%3B%22%3C%2FP%3E%3CP%3EHowever%2C%20even%20after%20adding%20them%20in%20the%20symbols.ldt%20file%2C%20the%20result%20was%20the%20same.%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20only%20change%20I%20have%20made%20that%20is%20different%20from%20the%20guide%20was%20to%20set%20the%20gAppUseBonding_d%20and%20gAppUsePairing_d%20to%200%20as%20I%20was%20having%20some%20issues%20when%20%3CSPAN%20class%3D%22%22%3Ereconnecting%20to%20the%20device%20but%20I%20do%20not%20think%20this%20has%20any%20effect%20on%20the%20updating%20part.%20By%20using%20the%20debugger%20I%20was%20able%20to%20see%20that%20the%20update%20seems%20to%20transfer%20correctly%2C%20however%20when%20the%20device%20resets%20I%20get%20a%20OTACFG_FW_UDPATE_FAILURE(0x4412d283)%20value%20for%20update_status%20which%20according%20to%20the%20data%20sheet%3A%20%22Indicates%20failure%20to%20process%20sb3%20file%20OR%20failure%20to%20erase%2Fwrite%20update%20status%20to%20OTACFG%20page%22.%20Any%20clue%20as%20to%20why%20this%20would%20happen%3F%20I%20am%20sending%20a%20.srec%20file%20created%20from%20the%20binary%20utilities%20of%20MCUXpresso%20through%20the%20NXP%20IoT%20Toolbox%20application%20on%20an%20iOS%20device%20if%20that%20helps.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3EKind%20Regards%2C%3CBR%20%2F%3ERidvan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1883859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20K32W148-EVK%20OTA%20updates%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1883859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20you%20already%20tried%20running%20the%20example%20from%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN13855SW.zip%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note-software%2FAN13855SW.zip%3C%2FA%3E%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20you%20made%20any%20other%20modification%20from%20the%20guide%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13855.pdf%3F_gl%3D1*1b5kumu*_ga*MTc1NzA3NDU1MS4xNzE3NDMxMDkw*_ga_WM5LE0KMSH*MTcxNzQzNDQ3OS4yLjEuMTcxNzQzODg3OC4wLjAuMA..%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13855.pdf%3C%2FA%3E%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3EItzel%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200in%3B%20font-family%3A%20Calibri%3B%20font-size%3A%2011.0pt%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1880071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20K32W148-EVK%20OTA%20updates%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1880071%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%2C%20I%20am%20using%20the%20SDK_2.12.7_K32W148-EVK%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1880064%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20K32W148-EVK%20OTA%20updates%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1880064%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EI%20will%20be%20helping%20you%20at%20this%20case.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ECould%20you%20tell%20me%20the%20SDK%20version%20that%20you're%20using%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
