JenNet-IP WPAN Stack. Transmissions error
gennadytanchin
Hello everyone!
MCU JN5168
I send packets from COORDINATOR to END_DEVICE:
Debug output:
Module: i6LP_RecvFrom( Socket=2, 0xfd040bd3:80e80002:2158d00:540de4, Len = 8)
Module: H->N (101)
Module: i6LP_SendTo(0xfe800000:0:2158d00:540de4, Port = 1190, Len = 10)
Module: <Sent>
Module: <RXD>
Module: H->N (101)
Module: i6LP_SendTo(0xfe800000:0:2158d00:540de4, Port = 1190, Len = 14)
Module: <Sent>
Module: <RXD>
Module: H->N (101)
Module: i6LP_SendTo(0xfe800000:0:2158d00:540de4, Port = 1190, Len = 13)
Module: <Sent>
Module: <RXD>
Module: H->N (101)
Module: i6LP_SendTo(0xfe800000:0:2158d00:540de4, Port = 1190, Len = 12)
Module: <Sent>
Module: <RXD>
Module: H->N (101)
Module: <Sent>
Module: <RXD>
Module: H->N (101)
Module: <Sent>
Module: <RXD>
Module: H->N (101)
Module: i6LP_SendTo(0xfe800000:0:2158d00:540de4, Port = 1190, Len = 22)
Module: <Sent>
Module: <RXD>
Module: H->N (101)
Module: i6LP_SendTo(0xfe800000:0:2158d00:540de4, Port = 1190, Len = 15)
Module: <Sent>
Module: <RXD>
Module: H->N (101)
Module: i6LP_SendTo(0xfe800000:0:2158d00:540de4, Port = 1190, Len = 11)
Module: <Sent>
Module: <RXD>
Module: H->N (101)
Module: <Sent>
Module: <RXD>
Module: H->N (101)
Module: <Sent>
Module: <RXD>
Module: H->N (101)
Module: <Sent>
Module: <RXD>
Module: H->N (101)
Module: <Sent>
Module: <RXD>
Module: H->N (101)
Module: <Sent>
Module: <RXD>
Module: H->N (101)
Module: <Sent>
Module: <RXD>
Module: H->N (101)
Module: <Sent>
Module: <RXD>
Module: H->N (101)
Module: <Sent>
Module: <RXD>
Module: H->N (101)
Module: <Send Fail> ErrNo: 57859
Module: <RXD>
Module: i6LP_RecvFrom( Socket=2, 0xfd040bd3:80e80002:2158d00:540de4, Len = 22)
Module: H->N (101)
What is this error: "... Module: <Send Fail> ErrNo: 57859 ..." (ErrNo 0xE203)
In "JenNet-IP WPAN Stack User Guide" this error not present.
Answer me, please, anyone.
Tags (3)
limcb
Hi could you add this to have more info ?
uint32 u32ErrCode = 0;
if (iSendToResult != 0) {
     u32ErrCode = u32_6LP_GetErrNo();
     DBG_vPrintf(TRUE, "\nError: %d\ncode: %d\ninfo: %d", iSendToResult,
                    (u32ErrCode & 0xff), ((u32ErrCode >> 8) & 0xff));
iSendToResult = result from Send command.
Example
int iSendToResult;
iSendToResult= i6LP_SendTo();
How fast are you sending the data ?
Can you check u16_6LP_GetNumberOfAvailableIPv6Buffers ? Make sure u16_6LP_GetNumberOfAvailableIPv6Buffers less than u16_6LP_GetNumberOfIPv6Buffers.
Is the END DEV sleepy or always on?
Is there a router to buffer the message in between the COORD and END DEV ?
