JN5189 Hight power module FCC
newdragon
The module was manufactured by referring to OM15072-2_MOD_EXT_AMP_QFN40_PCB2467-2.0.
FCC certified,
To pass, you must lower the output of channels 25 and 26 by about 12dBm and -3dBm.
A module called MSK32WT-M16 made by another company is also similar. How can I know how to solve this problem?
Labels (2)
Ricardo_Zamora
Hope you are doing well. Could you please help me check if this Application Note helps you with your requirements? JN-AN-1252 High Power Support
Also, I would recommend checking this community post: JN5189/K32W/QN9090 Radio certification documents - NXP Community
Hope this helps!
Ricardo
