JN5169 UART programming commands
deepanrajanbara
Hi ,
We wanted to program the JN5169 zigbee device  using the UART.
Please let us know, What are the bridge commands which can be used for programming the binary to the device.
What is the raw commands for the programming the device or what is the sequence to be followed.
Thank you,
Deepanraj.A
mario_castaneda
Hi Deepanraj,
Please look at the JN-AN-110 application note.JenNet-IP|NXP  The JenNet Protocol is not longer supported. But will find the Jennic Module Programmer.tar that will help you to send the binary file to the JN devices.
Hope it helps
Mario
