JN5168 bootloader
JN5168 bootloader
marianopucheta
Hi. I'm new to the JN5168. I bought 4 JN5168-001-M00 and started testing. I downloaded the AN1184_ZBP_Coordinator_JN5168.bin from JN-AN-1184 template. Then insert my code in the template and download it without problems. After that I could no longer burn again. I checked the cable and pin DO1 and everything is fine. I could even download the program in a new JN5168-001-M00 without problem.
There any application note about bootloader sequence?
Any suggestions?
