JN5168 bAHI_UartEnable code example?
2,258 次查看
shauntaylor
I've noticed that bAHI_UartEnable is the new alternative to vAHI_UartEnable but cannot find any example code using it. Can anyone point me in the right direction please?
标记 (1)
2,005 次查看
finstonian
you can find an example that uses bAHI_UartEnable in the following application note:
http://cache.nxp.com/documents/application_note/JN-AN-1223.zip
Check out the file uart.c in the Source\Common folder.
2,005 次查看
ygensas
This kind of example could be very usefull for me. Did you find one ?
Other question: I'm not able to download template (JN-AN-1158) for JN-5168. Do you have it ?
