Is there any document that describes bootloader (OTAP) for KW24D512?
1,593 次查看
paulosouza
I'm doing a firmware for KW24D and I want to integrate a over-the-air bootloader too.
I'm using BeeStack 5.0 and IAR compiler.
Is there a bootloader otap (.bin, .srec) for KW24D512 that is storaged in internal flash?
Is there any document that describes how to write the bootloader and the aplication on KW24D512?
标记 (4)
1 回复
1,461 次查看
stephanie_m
Dear Paulo Souza,
We no longer support/recommend BeeKit, but it is available for KW24D.  Currently the available devices with ZigBee support are the JN516x family.  The currently supported stacks by KW24D are: Thread, 802.15.4 MAC and SMAC.
ZigBee 3.0 will be supported in KW41Z in Q1 2018 and currently there are no plans to support this stack in KW24D.
Sorry for the inconvenience that this might cause you.
Estephania
