Is there a document describing the "Production Test API" for JN5179?
2,624件の閲覧回数
pmarcon
The only document I've found so far is JN-RM-2027, which does not include the JN5179 information.
I'm especially interested in the output power (in dBM) set on the JN5179 with vJPT_RadioSetPower.
Pierpaolo
2,416件の閲覧回数
mario_castaneda
Hi Pierpaolo,
Please take a look JN517x Integrated Peripherals API User Guide
2.2 Radio Power
https://www.nxp.com/docs/en/user-guide/JN-UG-3118.pdf
Note: As you know, the support for the JN517x is limited.
Mario
2,417件の閲覧回数
mario_castaneda
Hi Pierpaolo,
2.2 Radio Power
Mario
2,416件の閲覧回数
pmarcon
Hi Mario,
thanks for the answer, I assume that the JPT library is taking as input the same format of TX power values of the Peripheral API lib.
Regarding your statement on the limited support on JN517x, what do you mean exactly?
Many thanks,
Pierpaolo
