In Ble how to Send data from client to server and control the led
2,521件の閲覧回数
b_manojkumar521
Hello Team,
 I'm a beginner in rigado r14z
Currently working on BLE
In that can anyone explain how to send the data from the client to the server and with that data I need to control the led of the controller.
Thanks in advance
Stay Home.! Stay Safe .!
ラベル(2)
2,404件の閲覧回数
Sebastian_Del_Rio
Hi Manoj, I hope you're doing well!
Could you please take a look at the following community document?
https://community.nxp.com/docs/DOC-345405
It shows how to modify an SDK example to send a command over the air to adjust PWM using QN9080, but the steps work the same way for the KW41 or Rigado R41Z, because the stack implemented in the two devices is mostly similar.
Please let me know if you need any more information.
Sebastian
