How to store network data between resets
3,314 次查看
odd_bikes
Is it possible to store network data (PANID, channel, node information for coordinator, short address, PANID, channel for end devices) and allow the devices to resume communication after a network reset?
Thanks!
标签 (2)
标记 (1)
4 回复数
3,152 次查看
stephanie_m
Which protocol are you using ? Is it ZigBee? Thread? 802.15.4?
Estephania
3,152 次查看
odd_bikes
Thanks!
3,152 次查看
stephanie_m
You can try using the NVM_Interface APIs in your debug, could you please check them an verify if those are helpful for you ?
Estephania
3,152 次查看
odd_bikes
Sorry, maybe I wasn't clear with my question. The problem is not storing the data between resets, but how to use the stored data to resume connection from the end device to the coordinator, without scanning for available networks again and going through the association process.
Thanks!
