How to separate advertising data and scan response data by QN9021's Passthrough project?
1,427 次查看
tedwu1
I am using a BLE project of Passthrough 097. I decode scan response data at function of app_gap_dev_inq_result_handler in the file of app_gap_task.c. But, the system pass advertising data and scan response data to this function. So many advertising data interference scan response data decoding.
How to filter advertising data? Make the system not send advertising data to this function?
1 回复
1,408 次查看
mario_castaneda
Hi @tedwu1,
Could you please confirm the BLE example that you are working on?
I am not sure if I am following the issue that you are facing, Are you working with a central or peripheral device?
You could implement a filter policy but I am not sure about your application.
Mario
