How to send Coordinator data to SED
logum4
Hello Sir,
             I am using NXP JN5168-001-M00 module, application Note-JN-AN-1229-ZBPro-Application-Template-v1002.
I can send SED data to Coordinator. but i need to send coordinator data also to sed when sed's wakeup. Coordinator data received in SED some time only, that i mentioned below details.
1. power on SED device ( Initial time) - Data received success
PRIVATE void vHandleStackEvent(ZPS_tsAfEvent sStackEvent) ----------- app_coordinator.c
 case ZPS_EVENT_APS_DATA_INDICATION:
            DBG_vPrintf(TRACE_APP, "APP: vCheckStackEvent: ZPS_EVENT_AF_DATA_INDICATION\n");
                PDUM_eAPduFreeAPduInstance(sStackEvent.uEvent.sApsDataIndEvent.hAPduInst);
                APP_vSendPayload_Ucast(tempbuf,6,Clust_ID, Des_Address);     ------- >  coordinator data to sed  function
2. After received  SED's data, every time I am sending coordinator data to SED, i got success ack in coordinator but i never received that data in SED.
void APP_vtaskMyEndPoint (void)   ----- app_endpoint.c
    u16bytesread = PDUM_u16APduInstanceReadNBO(sStackEvent.uEvent.sApsDataIndEvent.hAPduInst, 0, "bbbbbbbbbbbbbbbbbbbbbbbbbbb",&payload);
                  DBG_vPrintf(TRACE_TRUE, "Read: %d, DATA : %x \r\n", u16bytesread,u8TempPayload);
                APP_vSendPayload_Ucast(tempbuf,6,Clust_ID, Des_Address);     ------- >  after received my sed data, i am sending coordinator data to sed function
Thanks & regards,
 Logan
mario_castaneda
Hi Loganathan,
Did you try to send this data when you received the data request from the SED?
Could you please provide your sniffer log?
The SED device needs the Pending internal flag when the coordinator wants to send some data.
Mario
