How to report Manufacturer-specific Attributes?
1,849件の閲覧回数
qingshuzhuang
I add a Manufacturer-specific Attribute in Electrical Measurement Cluster.
Now, I need report this attribute to coordinator when the value have change.
I have try use  “ Default Reporting”, “eZCL_ReportAllAttributes()”, "eZCL_ReportAttribute()" , they do not work.
A information in the description. " Only a standard attribute can be reported - a manufacturer-specific attribute cannot be reported. "
there have other way to report attribute?
ラベル(2)
タグ(3)
1,704件の閲覧回数
stephanie_m
I believe that the JN-AN-1223 will be helpful for you with the manufacturer's data, could you please check it ?
Estephania
