How to Enable Flash Protection on KW45?
bluechen
Ricardo_Zamora
Hope you are doing well. Most of the documentation is public now. Please refer to KW45/K32W148 Flash Encryption using NPX.
Ricardo
bluechen
Firstly, thank you for your response. My question was not clear. The protection I mentioned is not encryption, but rather measures to prevent flash from being written.That is to say, data written to flash can be protected and will not be tampered with
Ricardo_Zamora
I would recommend checking these Application Notes:
Hope this helps!
Ricardo
