How can I get the child node information?
sChameleoNz
I'm using zigbee coordinator example from SDK_2_6_3_ JN5189DK6.
But, I'm hard to get the child node's information.
How can I get it?
Please help me out.
Labels (2)
mario_castaneda
Hi @sChameleoNz,
Sure please look at the coordinator examples that we provide. JN5189/88.
JN-AN-1243 Base device Template
JN-AN-1247 IoT Control Bridge
To import this examples please follow the JN-AN-1260
Mario
mario_castaneda
Hi @sChameleoNz,
Please look at the ZPS_eAplZdpMgmtLqiRequest API that could help you requesting the information of your node.
If the device is the coordinator you could send the request to the address 0x0000 and increase the index if you don't know the child's address.
Mario
sChameleoNz
Hi @mario_castaneda,
I think my question had a lack of explanation.
As far as I know, zigbee coordinator keeps its child table.
I want to see this on my coordinator example.
mario_castaneda
Hi @sChameleoNz,
Sure, if you send this command to the coordinator, you will receive a response about the information that you have and the information that you need. You will receive a response ZPS_tsAplZdpMgmtLqiRsp.
https://www.nxp.com/docs/en/user-guide/JN-UG-3113.pdf 8.2.3.34 ZPS_tsAplZdpMgmtLqiRsp
Mario
sChameleoNz
I literally don't know about the nxp's framework.
I created the serial command for this.
But I don't know where to put my code for requesting.
And I don't know where to get the response as well.
Is there any example for this?
mario_castaneda
Hi @sChameleoNz,
Mario
sChameleoNz
It was very kind support.
I appreciate you.
Warm Regards,
sChameleoNz
