How Router works in JN-AN-1229 Application Note
4,705 次查看
dheerajsawant
Hello mario_castaneda‌,
I want to increase distance of JN5168 Module using Router.
But Don't Know From Where should i Start?
I am reading "Route Discovery" from PDF JN-UG-3113.
In Simple i want to achieve Mesh Network.
How it will be Possible?
Dheeraj
6 回复数
4,375 次查看
dheerajsawant
Any one know how to configure mesh network using zps configuration?
Dheeraj
4,375 次查看
mario_castaneda
Hi Dheeraj
I think this thread is related to the question
https://community.nxp.com/thread/469295
Mario
4,375 次查看
dheerajsawant
Yes mario_castaneda‌,
but  i little bit understand about this thread,
how i do this?
open zps configuration in beyond studio.
create new sibling of router as sleeping end device.
as router create child(SED) , that child(SED) will connect to coordinator through router.
because of that communication range increase.
(i think  my this problem is solved and looking for another thread which is "SENDING DATA FROM COORDINATOR TO SLEEPING END DEVICE".)
(if  i am doing somewhere wrong please inform me.)
BEST Regards,
Dheeraj
4,375 次查看
mario_castaneda
Hi Dheeraj,
Yes, The router opens up the network for other devices to join, child(SED) will connect to coordinator through router
Mario
4,375 次查看
dheerajsawant
Have you work on it?
because i am still looking for the solution.
Dheeraj
4,375 次查看
dheerajsawant
Does Anybody Know how mesh Topology possible in JN5168-001-M00 module.
i am using JN-AN-1229 Application Note.
i am successfully completed communication from Sleeping End Device to Coordinator.
Now i want to Increase distance using Router.
Any One know how it will Be possible?
Dheeraj
