FRDM-KW41Z d-flash read write (FlexNVM)
2,057件の閲覧回数
satsok_n
I would like to know if in FRDM-KW41Z there is any other way than the flash_config_t flash driver to read and write in flash memory. Furthermore I was able to write on Pflash. Is there any example of FlexNVM for KW41Z?
タグ(2)
1,994件の閲覧回数
Sebastian_Del_Rio
Hi Kostas, I hope you're doing well!
Just to clarify, the KW41Z does not have a FlexNVM or a FlexNVM driver included in the SDK, your option for controlling flash memory would be to use the fsl_flash.c driver.
I'm sorry for the inconveniences this may cause.
Please let me know of you have any other questions.
Sebastian
