FRDM-KW38 CMW270
FRDM-KW38 CMW270
1,245 次查看
Yuichiro_Hara
Mbed Serial Port driver download from mbed
But, V6.3 folder does not exist, and even the latest version is V6.15.
Also, I tried with V6.15, but I could not install it due to the following error.
Error code・・・「The driver could not be installed. No mbed Microcontrollers were found.」
What should I do?
1 回复
1,222 次查看
EduardoZamora
Hello @Yuichiro_Hara
Hope you are doing well.
Just to confirm, are you trying to perform a RF evaluation test (FRDM-KW38 RF System Evaluation Report)? If so, could you please help us with more details about your test setup?
Eduardo.
