Example code of ESP8266 Wifi Module on LPC865M201JHI48
BerlinRaj
Hello NXP Experts,
                      Hi, I want to interface an ESP8266 Wi-Fi module with my LPC865 customized board. I'm new to working with Wi-Fi. Initially, I plan to interface the USART using the polling method. Can anyone provide guidance on how to interface the ESP8266 Wi-Fi module with my controller, along with any example code?
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, I recommend use the SDK example to review how the communication is done.
Select Board | MCUXpresso SDK Builder (nxp.com)
Best regard,
Pavel
BerlinRaj
hi @Pavel_Hernandez   i already have  LPCXpresso860MAX SDK. where is the example driver?
can you show me that?Screenshot 2024-08-10 095443.pngScreenshot 2024-08-10 095443.png
Pavel_Hernandez
Hello, need to select one and then click finish.
Maybe the fist is what you are looking for, only need to modify for your application.
Pavel
BerlinRaj
@Pavel_Hernandez  Sorry for my late reply. I've been working on another project. Why did you relate the loopback example to the driver? I'm actually working with the ESP8266 Wi-Fi Module. Could you please explain the initial steps I need to take and what the most relevant examples are?
Pavel_Hernandez
Hello, I based the recommendation on this comment "I plan to interface the USART using the polling method." I suggest use the example below, because the polling method is blocking mode.
Pavel
BerlinRaj
Please reply..
