EVK V/S Localization board
Chan_17
Hi team,
i am using KW45 localization and EVK  board .
i took sdk example of eatt_central its working good in EVK board  means getting multiple device data properly but if i use localization board i am not reciving proper data from multiple device. what may be the reasons for data loss in localization board?
luis_maravilla
Hello
Could you help us confirm, have you ported the code from KW45B41Z-EVK SDK to KW45-LOC with corresponding hardware configuration, or did you directly flash the code from KW45B41Z-EVK SDK in the KW45-LOC?
Are there modifications implemented in the code?
What SDK version are you using?
Is the EVK board flashed with eatt_central or peripheral? And the KW45-LOC?
In Bluetooth Low Energy Demo Applications User’s Guide Chapter 5.4.2 are described the supported platforms, according to this list only the KW45B41Z-EVK is supported
Best Regards
Luis
%3CLINGO-SUB%20id%3D%22lingo-sub-2166037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EEVK%20V%2FS%20Localization%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20team%2C%3C%2FP%3E%3CP%3Ei%20am%20using%20KW45%20localization%20and%20EVK%26nbsp%3B%20board%20.%3C%2FP%3E%3CP%3Ei%20took%20sdk%20example%20of%20eatt_central%20its%20working%20good%20in%20EVK%20board%26nbsp%3B%20means%20getting%20multiple%20device%20data%20properly%20but%20if%20i%20use%20localization%20board%20i%20am%20not%20reciving%20proper%20data%20from%20multiple%20device.%20what%20may%20be%20the%20reasons%20for%20data%20loss%20in%20localization%20board%3F%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2166037%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EDevelopment%20Board%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2166146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20EVK%20V%2FS%20Localization%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2166146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ECould%20you%20help%20us%20confirm%2C%20have%20you%20ported%20the%20code%20from%20KW45B41Z-EVK%20SDK%20to%20KW45-LOC%20with%20corresponding%20hardware%20configuration%2C%20or%20did%20you%20directly%20flash%20the%20code%20from%20KW45B41Z-EVK%20SDK%20in%20the%20KW45-LOC%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EAre%20there%20modifications%20implemented%20in%20the%20code%3F%3C%2FP%3E%0A%3CP%3EWhat%20SDK%20version%20are%20you%20using%3F%3C%2FP%3E%0A%3CP%3EIs%20the%20EVK%20board%20flashed%20with%20eatt_central%20or%20peripheral%3F%20And%20the%20KW45-LOC%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EIn%20%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fmcuxsdk%2Flatest%2Fhtml%2F_static%2Fwireless%2FBluetooth%2FBluetooth_Low_Energy_Demo_Applications_User%2527s_Guide.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EBluetooth%20Low%20Energy%20Demo%20Applications%20User%E2%80%99s%20Guide%3C%2FA%3E%20Chapter%205.4.2%20are%20described%20the%20supported%20platforms%2C%20according%20to%20this%20list%20only%20the%20KW45B41Z-EVK%20is%20supported%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%0A%3CP%3ELuis%3C%2FP%3E%3C%2FLINGO-BODY%3E
