DiRaNa 3 - IQ File
DiRaNa 3 - IQ File
1,681 次查看
gopalakrishna
One of application, using DiRaNa 3 Module (SAF7754HV/N208WK) for DRM30 application.
As a part of hardware qualification looking for IQ file.
Help me how to get the IQ file and how to load the file in to signal generator.
Planning to use R&S Make signal generator to simulate the DRM signal.
SMCV100B: 8kHz to 3GHz Vector Signal Generator with AM/FM/RDS (opt K155) & DRM (Opt K160).
https://www.rohde-schwarz.com/in/products/test-and-measurement/vector-signal-generators/rs-smcv100b-...
 Thank you.
Gopala
1 回复
1,660 次查看
TomasVaverka
Hi Gopala,
I am afraid you will not get the required files here on the public community. As far as I know, this module is not a mass-market product and in order to get any support, you should reach out to your local NXP sales representative.
Tomas
