Coordinator backup JN5189
Marcin1
Is there any possibility to make Zigbee Coordinator backup? Coordinator is on JN5189 chip.
What is the simplest way to restore control of the network in case of this network coordinator dissapears? Only restart all nodes and make new network with other coordinator?
Marcin
mario_castaneda
Hi @Marcin1,
I hope you are doing great.
You could create a new network as you mention you are right.
But also remember, that the Trust Center is the one that could accept new join devices and also is the one that keeps all the routing tables. You could assign the TC to a different device.
Mario
