Controlling Kinetis Protocol Analyzer from a command line
1,987 次查看
wbober
Hi all,
Is there a way to control the application from a command line, i.e., select channel and adapter? We'd like to use the application in automated testing framework to capture 802.15.4 traffic.
Kind regards,
Wojtek
标签 (3)
1,772 次查看
stephanie_m
Sorry for the late reply and the inconvenience this might cause you but unfortunately it is not possible to configure those characteristics through a command, the only thing available it’s the GUI you are using it.
Estephania
