Case portal login error
2,823 次查看
sumi
Dear Supoport
I can no longer log into the case portal.
What should I do.
Sumi Kenji
5 回复数
2,714 次查看
sumi
Dear Supoport
I can now log into the case portal with my account.
thank you.
Sumi Kenji
2,732 次查看
sumi
I received the following message.
the problem is not resolved.
I am in the middle of inquiring about the WPA3 problem of 88MW300 on Kportal, and I am in a lot of trouble.
No one can help me with the problem of not being able to log into the case portal.
Your topic recently received replies.
Topic: Case portal login error
Date: 01-25-2023 07:17 PM
Did it solve your problem?
Click here to view the replies and mark one as an Accepted Solution.
This helps others find helpful answers in the community too!
2,766 次查看
sumi
Hello. Tech support.
I reset my password from my profile page.
But I get a login error.
The following is displayed on the screen.
Login to NXP Case Portal not successful
Sumi Kenji
2,785 次查看
sumi
Try resetting your password.
Sumi Kenji
2,794 次查看
EduardoZamora
Hello @sumi
I already sent you a community private message.
Eduardo.
