CLRC663 I2C LoadProtocol Error
2,006件の閲覧回数
octopus
I am using CLRC663 with I2C configuration in my project. eeprom error occurs every time I try to send load protocol command. Is there any known error about this situation?
タグ(1)
1,996件の閲覧回数
stephanie_m
Please help us check the following AN for more details on the load protocol.
1,981件の閲覧回数
octopus
Thank you for answer. I figure out LoadProtocol problem. It was about how write FIFOData register so this is solved. But I have another problem. When I tried to use transceive command, again EEPROM error is occured.
I am using STM32 as MCU and I2C as communication protocol.
