Bootloader in KW45
Bootloader in KW45
2,041 次查看
Chan_17
Can we build custom bootloader for KW45 ?
Can we program other MCU using KW45 (consider other MCU can be reprogrammed via  its spi) , so here how can we give other MCU hexfile/firmware to KW45 . Please let us know if there is any Application note
1,905 次查看
luis_maravilla
The NTM88 is an old sensor; I would recommend redirect this question to Analog and Sensors Community to find more information regarding the NTM88.
Here is a Link for it Sensors - NXP Community
I really apologize for the inconveniences this might cause you and your project.
What you could review is this Application note that describes using NTM88 with a MCU Host, please check this guide to see if adjust to your necessities.
Implementing Wired Communication with the NTM88  AN14182, Implementing Wired Communication with the NTM88 - Application Note
Thank you for your interest in NXP Semiconductor products
Best Regards
Luis
4 回复数
1,978 次查看
luis_maravilla
Could you help us explain more details about what you trying to achieve?
Are you using a KW45 EVK board? Or the KW45 in a custom board?
Could this Application note available for KW45 explain what you trying to achieve? Please refer to introduction section.
Custom Bootloader using OTAP--AN13860
Creating Firmware Update Image for KW45B41Z/K32W148 using Over the Air Programming Tool
Custom Bootloader with Fuses--AN13883
Updating KW45 Radio Firmware Via ISP Using SPSDK
Best Regards
Luis
1,925 次查看
Chan_17
hI Luis,
Thanks for replying!
We are using KW45 EVK board . We want to program NTM88 MCU via spi of other MCU (this application note is there in NTM88 documentation https://community.nxp.com/pwmxy87654/attachments/pwmxy87654/sensors/8058/1/NTM88_SPI_Reprogramming_r...). In our case other MCU is KW45 . So to program NTM88 through KW45 we need to take firmware of NTM88 inside kw45 first and then with spi we need to transfer it to NTM88 .   This is what we want to achieve . Is it possible then how?
1,906 次查看
luis_maravilla
Best Regards
Luis
1,997 次查看
Chan_17
Please check , we struck in this .
