Bluetoot mesh Stack for K32W148
1,782 次查看
HiroakiOkoshi
For my customer, the availability of this stack is the deciding factor, but is the Bluetooth mesh stack available for the K32W148?
1,732 次查看
Christine_Li
Hi, @HiroakiOkoshi
I am so sorry to let you know that after confirmed with our AE team, the Bluetooth Mesh is not supported on K32W148.
I apologize for the inconvenience to you.
Christine.
1,754 次查看
Christine_Li
Hi, @HiroakiOkoshi
I checked some documents related to K32W148, and not found Bluetooth mesh Stack information.
So I think it might not support.
But I will check internally and double confirm, then let you know.
Christine.
标记 (1)
1,733 次查看
Christine_Li
Hi, @HiroakiOkoshi
Christine.
